vcStringEnumProperty
Typed property that holds a value with a description, limited by a pre-defined set of values.
Parent: vcProperty
Children: vcAvoidanceQuality, vcBackfaceMode, vcBitmapFileFormat, vcBitmapFormat, vcChartDataType, vcChartTileType, ... (see more)
vcAvoidanceQuality
vcBackfaceMode
vcBitmapFileFormat
vcBitmapFormat
vcChartDataType
vcChartTileType
vcChartType
vcClippingMode
vcCollisionTestMethod
vcConnectorTestLocation
vcConnectorType
vcEdgeShadingMode
vcEnumPropertyType
vcExpressionPropertyType
vcFocusModeDynamicSetting
vcJointAxis
vcJointServoType
vcJointType
vcLayoutItemType
vcLightType
vcLimitPropertyType
vcListPropertyType
vcMaterialDepthComparison
vcMaterialInheritance
vcMaterialOpacityType
vcMaterialRenderOrder
vcMatrixFormat
vcMenuTool
vcMessageBoxButton
vcMessageBoxImage
vcMessageBoxResult
vcMessageType
vcMoveType
vcNodeListEntryScope
vcNodeListEntryType
vcNodeSynchronizationType
vcNodeTreeScope
vcPackFolderState
vcPdfExportLevel
vcPropertyType
vcQuantityKind
vcReferencePropertyType
vcRenderShadingMode
vcSimNodeType
vcSimulationLevel
vcSimulationState
vcStepPropertyType
vcSweptVolumeDecompositionType
vcSweptVolumeMethod
vcVolumeDetectorTestMethod
| AllowedValues | list | RW | Gets or sets a list of allowed values for property. Each item is a tuple of (value, description). |
| Type | vcEnumPropertyType | R | Gets the type of the property. |
| Value | String | RW | Gets or sets the property value. |
| ValueDescription | String | R | Gets the description of the current property value. |
| waitFor | object | String OR None value, Optional Keyword[waitTrigger = Boolean] | Blocks script execution until vcProperty.Value is equal to the "value".See moreThis function returns an awaitable task. It must be awaited. Parameters: value (object): Value that is used for comparison. When the value is equal to vcProperty.Value, the task completes. Optional: waitTrigger (boolean): False by default. When waitTrigger is True, the task will wait for the value to change first, before comparing it against "value". Otherwise, the comparison is done immediately and when the values match, the task will complete without blocking the script. Returns: Awaitable[List]: The task instance. When awaited, returns a list of event arguments that the event has been triggered with. |
| waitForNot | object | String OR None value, Optional Keyword[waitTrigger = Boolean] | Blocks script execution until vcProperty.Value is not equal to the "value".See moreThis function returns an awaitable task. It must be awaited. Parameters: value (object): Value that is used for comparison. When the value is not equal to vcProperty.Value, the task completes. Optional: waitTrigger (boolean): False by default. When waitTrigger is True, the task will wait for the value to change first, before comparing it against "value". Otherwise, the comparison is done immediately and when the values do not match, the task will complete without blocking the script. Returns: Awaitable[List]: The task instance. When awaited, returns a list of event arguments that the event has been triggered with. |
